Renix 4.0 idle
summitlt
Maine
What is it supposed to be? I cant seem to fine a number. Mine idles at around 1000rpm, and im sure thats a little high.
1990 MJ, 4.0, ax-15, np231.
What should I look at to ge tthe idle down?
1000 is on the high side. 800-1000 is I believe what it should be at. 750 in gear.
750 with a stock alternator. Some aftermarket alternators require a little higher rpm.
600-700 is normal. A high idle is normally caused by a vacuum leak. Most common point is the hardline running by the battery and going to the canister mounted behind the bumper. Right by the battery it tends to fail.
