fatwreck
- ottawa, il
The front output seal on my 231 tcase has been leaking lately. I picked up a new one and I finally got around to replacing it. The problem is that I can't seem to get the old one out.
I trashed the rubber seal part of it so far....but I can't seem to get the metal ring out.
Do you have any suggestions WITHOUT pulling the front half the tcase off? I really don't want to do that unless I ABSOLUTELY have to.
If I had access to it like a pinion seal, then it would be no problem....but my access is limited because of the belly pan I have.
I'm thinking slide hammer or some sort of seal puller. Suggestions?
Thanks.
Thanks.
