- Yucaipa, CA
Dan 'Glad you're OK' Turner
Dan Turner said:This is definitely not the right way.![]()
Jump This said:I see no picture!
What did you do Remi?
Roll?
Thump a rock?
Rock thump you?
Inquiring minds need to know!
Rick R
Nope, hinge is messed up and it don't closeJump This said:It looks like that left side passenger door is okay...
I bet Ryan could use it!
Maybe Brandon too....
(it doesn't look like you will be needing it!) :dunno:
Rick
Well I kind of did: I started with rubber down and that's where I ended up! Btw, how's your XJ doing?mikeyl said:glad you're ok remi! i'll have to get you one of my "keep the traction side down" stickers for your next ride!
mikeyl said:drives me crazy. put my old radiator back in after rodding it and it runs cooler than the 3 row gdi new. i still think it is a bit warm for a 180 thermo. but as to the fire stuff, all it took was to splice in 4 wires on the O2 sensor,change the fuel line and it was good to go. unfortunatly it was overheating enuf to not be able to make big bear. that might be fixed now. i think i need to drop a thermocouple in an old temp sensor socket and measure the actual temp.
