TheNerd
- San Diego, CA
Flyfisher said:I'll agree with Matthew Curie...those cheap hitch pins can withstand a lot of shear stress...but bending stress is another story! At least the hitch pin method is loads better than using the hitch ball! NEVER use the ball...it will become a cannonball when it fails!
A little napkin calcs over here are telling me that loading the pin directly with your recovery strap will basically result in the same stresses as doing it through a hitch insert.
Pulling on the hitch Pin (Simple supports, disctibuted loads):
Max Shear ~ 1/2 Pulling Force
Max Moment (Bending) ~ 1/4 Pulling Force
Pulling on the Hitch insert (Simple supports, twin loads / 4-pt. bending):
Man Moment (Bending ) ~ 1/4 Pulling Force (I rounded 7/32 up to 1/4... so this is technically slightly less bending on the pin)
...so save your $$$ on a shackle hitch and pull right on the hitch pin. Plus, if something were to fail, you have a lot less mass flying around...
