Buck Jackson
- Vancouver Island, Canada
Length determines the angle, and also how much "hold" your swaybar puts on the articulation of the axle. With shorter links, you limit your axle's motion, thereby translating to a stiffer ride. Try lifting 5" and running stock swaybar links, you will compress your front suspension and create a much stiffer ride...You are talking about torsional flex, not stiffness. I guess it could be argued that a larger diameter bar made from material with a higher tensile strength will provide greater resistance to the torsional flex put upon the bar by articulating the suspension, and therefore provide a stiffer-feeling ride, but again, that is not the stiffness of the bar, its the stiffness of the ride. A minor point, but then again, I was just being facetious!Talyn said:No, the length of the link determines the angle of the sway bar, not the stiffness. There is a specified correct range to set a sway bar at. And, yes there are stiffer sway bars for the XJ. I know Addco makes them. Don't know who else.
-Chris
Buck :canada:
