MYRZ98XJ
- CENTRAL ILLINOIS
First post here, discovered this forum from fella's over @ jeepsunlimited, anyway I'm about to embark on putting my 3'' springs (rear)on this weekend and have soaked the he## out of the front leaf spring eye's good with PB. I saw where a guy cut thru spring eye and chopped remaining bushing out to reveal bolt, would this be a way to get past cutting hole in body or frame to access possible nut weld breakage? The way I see it I wont need the old leaves so why not trash the spring to get to the bolt? I simply KNOW mine will break off since I broke tc bolts ,upper rear shock bolts Etc Etc off already! I figure once I get a clean shot at bolt a little heat and no bushing to hold me up should free the PITA bolt? PS -DD- so attempting all the preplanning possible. I've read countless threads on others demises and hope to have a good shot at it.(yeah right). Any thoughts appreciated!
