Jonner
- Charlotte, NC
Long-timer lurker here.... looking to contribute back to the Naxja community. I'm halfway through a drum brake rebuild and thought I'd share some things I've learned along the way. I've replaced master cylinders and done plenty of caliper brake jobs but never done drums...
1) If you're not familiar with drum brakes, once you get the drum off, take pictures from multiple angles and DO NOT take apart more than one side at a time. I took 5 pictures of my brakes and sent them to my email so I could look at them on the laptop by my side while I reassembled.
2) Buy the right tools... these things are helpful. Drum brake multi-tool, T-handle hook (I used this the most), brake spoon tool, spring tool (it looks like a screwdriver handle with 2 circular ends of different sizes), and flare nut wrenches.
3) If you're replacing wheel cylinders, expect to replace the hard lines. I'm watching youtube and scouring
for tips on flaring and bending brake lines. Even though the nut turned, the line didn't and it snapped clean off.
4) Having a second car takes the stress level down a huge notch.
5) NAPA's spring kit used shoe retaining springs that have the same diameter the whole way down... this means that the bottom of the retaining springs do not seat down into the shoe. This resulted in lots of cussing... until I used a C-clamp to hold the shoe in place. This trick solved the problem of aligning the springs, the pins behind it, the little spring cap and shoe all at the same time.
6) Look into a buying a pressure bleeder. I use a Motive brake bleeder which makes bleading an easy 1 man job.
AND Tomorrow... I get to source a tubing bender, flaring tool, close quarters cutting tool, 3/16" brake line, and at this point I'm hoping to reuse my flare nuts but don't know if that's possible yet.
