So it's long past time to change the fluid in my rear differential, and I'm stuck on the same question that has kept me from changing this.
Do I have a limited slip differential, which needs a friction modifier in the gear lube?
This is for a stock '98 XJ SE, with 4WD (part time) and is an automatic (AW-4) with 4.0L engine.
Is there a way to determine if I have the LSD, and need a friction modifier?
Thanks!
Thanks!
