Rear Brake Lights Not Working . . .
Red1
It is probably the fuse, but I do not know. Where are the fuse(s) for the rear brake lights? ? ?
I doubt that it is the switch, because the brake light inside goes on when the emergency bake is on. The running lights turn on, but no brake lights.
Last thing, if it is not the fuse, what else could it be?
THANKS!!!!!!!!!!!!!!
The fuse, the lamps, the switch or the wires. Don't discount the switch, the parking brake doesn't activate the brake pedal switch.
Brake Lights
The light inside the jeep goes on when the parking brake is on, so I would think normal brake lights would turn on too (they use to).
Where the heck is the fuse for the rear brake lights? And is there more than one?
Thanks!
First, as already stated, the interior brake warning light (for the parking brake) is in no way connected to the brake lights at the rear of the vehicle, so don't even think about a correlation.
Second, different year XJs have different wiring and different fuse panel locations, so you should include the year and model in your post when asking for help. If you have an '84 through '96, the fuse is in a panel under the dashboard, up over the driver's left foot. If you have a '97 or newer, there are two fuse panels, one under the hood and one in the front passenger footwell, behind the trim panel forward of the front door. I don't know which of those might hold the brake light fuse.
Check the switch first. It's a mechanical switch mounted under the dash that operates a plunger as the pedal swings.
One more thing
It is a '91 with 230,000 on it and still purring like a beast. Been in the family and looks BRAND new. Take Care
230? cool!! I'll be hitting 200 here in a month or so. And I don't even change my oil regularly..... I love Jeeps
