rear axle play
tag
HI,
is it normal to have play on rear axle? wheel bearings are ok ! but if i pull the wheel it moves out about a quater inch , both sides iv'e been told this is normal on cherokee, ?.......thanx
tag said:
HI,
I believe that if you have a c-clip axle, then yes, but without knowing what your axle is, there is no way of knowing.
its like a real thick washer in the shape of a "c" that holds your axle inside the carrier. no big deal really. a few people have had the c clip fall out or work its way out and then have their axle walk out of the housing which probably made their day a bit harder than normal.
