Reader's Rig's
sjd78 said:
Here is mine...
nice..specs?
53guy said:
nice..specs?
98 cherokee, 5.5" lift using T&T long arm upgrade w/ t case skid and RE coils, leafs, track bar/bracket/brace, RE monotube shocks, T&T frame stiffeners, D30/D44 with Alloy USA shafts, Detroits and 4.88's. 35" BFG M/T on 15x8 Soft 8 wheels. Home fabbed sliders and roof rack. I think that is the main things you would want to know. If you have any more questions please ask :cheers:
It's changed some since my last post to this thread...
I've updated my XJ a bit.
Here's the long and the short of it.
  • D44 front axle from a '79 F-150
    • Warn locking hubs
    • TNT truss and control arm brackets
    • Detroit locker with 5.13's
    • Dedenbear knuckles and Blue Torch Fab steering arms
    • PSC hydro assist
    • Bilstein 5125 shocks
    • ACOS Coil spacers
  • Ford Nine inch from a '79 F-150
    • Ford 8.8 disks
    • True hi-9 third member
    • Detroit locker with 5.14's
    • Bluetorch Fab Hi-9 skid plate
  • Stock 4.0 with a couple under hood mods
    • Home brew relocated air filter
    • Dual batteries (one red, one Yellow)
  • NP 231 C-J t-case (Chevy S-10 internal parts, wider chain and 6 planetary gears)
  • 35" MTRs with Crager 8" steelies
  • JCR Stage 1 winch bumper
    • Superwinch EPi 9.0
  • Home brew rear bumper
  • Longview 4x4 driveshafts
  • TNT "frame" stiffeners
  • Second crossmember to hold Home brew skid plate
  • Rockers replaced with 3x5 box steel
  • Home brew half doors
Up coming changes
  • Stinger hoop on front bumper
  • Lower quarter panel coverage added to rear bumper
  • Rework the roof rack to allow winching up and down of the spare tire
  • Roll cage
  • Rear cargo area floor cut to pass gas tank through
  • Rear shocks through the floor
Anything else you want to know? Just ask.
DAryl
I'm closer to my goal so I'd decided to finally post up some pics:
some of the specs:
  • 4.0 L Inline 6
  • K&N FIJK Intake
  • Jet - Stage 1 Performance Chip
  • Flowkooler Hi-Flow Water Pump
  • Turbo City Hi-Flow Thermostat Housing
  • Turbo City Hi-Flow 180 deg Thermostat
  • Performance Distributors cap
  • LiveWires ignition wires
  • Screamin Demon Coil
  • Magnaflow Performance Muffler
  • Raised Hood (washers)
Suspension:
  • 4.5" Rusty's Front and rear springs
  • RE Dropbrackets and Braces
  • RE Adjustable upper & lower control arms
  • JKS Adjustable Coil Over Spacers
  • JKS Adjustable Bumpstops
  • JKS BPEs
  • JKS Quicker Disconnects
  • 1.5" rear shackles
  • 1.25" drop pitman arm
  • RE HD Trackbar
  • RE HD Trackbar Frame Mount
  • RE Trackbar Mount Reinforcement bracket
  • DPG Rear Adj Bumpstops
Steering:
  • JCR 1-Ton Steering Tierod and draglink
Driveline:
  • HP D30 Front Axle with Auburn Ected 30 Locker
  • Alloy USA Front Chromoly and Rear Axle Shafts
  • Alloy USA D30 Axle Seals
  • Alloy USA 4.56 R&P - Front N Rear
  • Chrysler 8.25 with Detroit EZ Locker and ZJ Disk brakes
  • JB Conversions Super Short SYE
  • Tom Woods DC Driveshaft
  • Factory front driveshaft rebuilt by OC Driveline
  • 33x12.5x15 Goodyear MT/Rs
Armor:
  • JKS SuperNerfs
  • cRok Inner Brace
  • Trimmed Fenders with relocated Factory Flares
  • Protofab Winch Bumper
  • Rigidco Rear Bumper, Tire Carrier, Hi-Lift mount, and jerry can mount
  • PMW Door Guards
  • Ruffstuff 8.25 diff cover
  • Riddler Mfg D30 Diff Cover
yekcid said:
Are those the factory rear end caps, or a new wrap-around design from RigidCo? I'm guessing they are the factory ones.
factory end caps cut to fit
'87 2 door
4.0L, low end cam, stiffer valve springs, header, Still Renix though. But not 4 long!
HP non disco D30, D44, 3.55's - both open, workin on that too. stock AW4, NP242
3" lift, Bushwackers, 33" MTR's 15x10 steel wheels. Stupid loud stereo!
Sorry, They're all posers.
tribalmentality said:
'87 2 door
no way you got the rare rubicon xj? how do you like it?
j/k
Current state as of July 07:
Specs you can see:
35x12.50 MT/Rs on 15 x 8 chromies
5" mix/match lift (mostly RE HD adjustable stuff, some skyjacker, some rusty's, bilstein)
home brew and/or custom built bumpers and rails
6" x 6' garvin wilderness rack w/ floor, tire mount, and hi-lift mount
Warn XD9000i winch with synth rope
dual bander ham antenna
tinted tailights (with special light paint, and no, I don't know where you can get it)
clear corners
Specs you can't see:
too much to list, locked 8.8 in the rear with crane cover, 4.56 gears, currie steering, alloy axles up front, no SYE, yadda yadda, mike-g.net/jeep
past versions :D...
http://www.naxja.org/forum/showthread.php?t=926547
Heres my jeep i bought a few weeks ago. Few things have changed since these pics were taken.
Added a flowmaster exhaust and BDS 6.5" long arm kit and MT MTZ 35" tires.
Picked up a new XJ, little nicer rig for the family than my 91.
01 Sport
4.0L/AW4/NP231
LPD30/8.25
33" BFG ATs
ARB front/custom rear with tire carrier
Skids all around
Tuffy drawer bolted in back
Plans for it are new leafs to replace the sagged ones, new coils to correct the gangsta lean, swap the ATs for MTs and eventually a front locker.
Got the T-Max swapped over from the 91 with a little help from the oldest:
finally got her set up just about how i want her. next up is probably a cage, then longarms, then 33s, then...... :D
fabtech 4.5" coils and tubular lower arms with johnny joints at both ends
rancho 3.5" rear leafs with 1.75" boomerang shackles
RE adjustable trac bar
JCR offroad prerunner stage1 front bumper
detours USA rear bumper
procomp MXR resevoir shocks
6" spotlights converted to 5000k HID
hanneman fiberglass 6" bulge front fenders
hand wound 290 amp stinger electronics alternator
2 15" kicker competition CVR DVC 4ohm subs
1500w hifonics zeus class D mono amp
5.25" speakers all alpine s-10
alpine cda-9815 head unit
7" screen in dash where lower AC vent and ashtray used to be
ps2 under drivers seat
3000w power inverter under rear seat with 4 110v household plugs (great for running a projector off the ps2 out in the big sand dunes or on the side of a cliff :D)
i replaced every interior bulb with a high intensity blue LED
15x8 black steelies wrapped in 31x11.50 bias ply TSL swampers for the mud, street and sand tires are 31x10.50 mickey thompson "dick cepek FC2" radials
hmmm i think thats it.
JV. Sledge Hammer
Photo by Mile L.
Coyote Lake
Photo by Phil M.
Dusy Ershim
Photo by Slonopotam
Courtright
Photo by Slonopotam
Swamp Lake
Photo by Jes
Brewer Trail
Photo by Tim P.
Hollister Hills
Photo by Letterman
The Whale Bone
Photo by Andy P.
Snow Run
Photo by Letterman
Poser Shot
Photo by Mike "Balls in Mouth" Walls
Here's the latest pic of my new "rig" waiting to run with the GLJT guys at the Badlands. YES, it's stock but at least I yanked off those STEPS in the parking lot over by the snack stand and threw em in the dumpster.
Wife was pissed tho! :nono:
here's my junk... hoping to just get her cleaned up and throw a set of bumpers and a winch on her this winter and wheel the crap out of it in between
