jeep_87_cherokee
- Waverly, IL
i am think about useing a long arm front suspension like the RE radius arm setup, i want to run 2 lowers with one upper coming off the lower arm, Which side of the axle would it be better to attach the upper arm to ?? , i can fab a truss for either side, but which side would be better to have the upper arm attached to.
has any one designed/used a "extended sized" upper arm that mounts further back than the factory uppers ??? , i was thinking RockKrawler had some sort of a setup like this but i wasnt for sure.
Would any one recomend running long arm lowers and useing RE adjustable upper in the factory position ???? would it still flex good ?
i'm going to (*try to*) run 8" of lift with the dana30 (*if it last*) on a 1987 cherokee,
thanks , Luke
thanks , Luke
