Bones
- Mid Missouri
After my little incident in Moab last Oct (yes, Beezil was involved
) my XJ sets about .75-1" lower on the right side. I know I tweaked my Nat’l spring pack when the fit hit the shan.
I am presently running an RE sold 10 leaf Nat'l pack with a long leaf out of an old OldManEmu set of leafs thrown in. I have the packs on what is approx. equal to a 1.5" lift shackle and a 2" tapered block for a lift height of a measured 6.5" at the driver side "frame" and about 6" at the passenger side "frame" (thus about .75-1" lower at the fender flare). The drop is front and rear on the passenger side and is not related to any passenger weight (said for the wife's benefit
I will be switching my present crapola front springs for a set of RE ZJ 4.5" springs, but I do not want to trash this set of leafs.
I don't mind the added leaf or even the block that much as long as flex and ride are good however I want to regain the height I should have. The packs are an advertised @ 4.5" but RE can't tell me the spring rate and said that I should call Nat'l, and Nat'l said they didn't make springs for RE. It's the typical runaround scenario.
Anyway, what is involved in re-arching and how do I re-arch without knowing the original arch and spring rate?
Is it something any shop can do or do I need to find someone at Nat'l that actually knows something and have them do it?
Does anyone know the spring rate and free arch of the RE Nat'ls?
Thanks,
Bones :skull1:
#6
Thanks,
Bones :skull1:
