MAP
- Wilmington, California
I have a slow rattle type sound that comes from the front end. I ended up replacing the sway bar bushings and that eliminated some of the noise but it appears that it was masking the other sound.
This rattle only occurs when I'm going over bumpy areas. One bump won't do it. It seems to be coming from the right side.
I got under the XJ and tried moving all the control arms by hand but they don't move. The rubber does seem cracked though.
Do I need to let the axle hang by lifting the XJ at the body? Will this make a worn control arm bushing more obvious?
I also have noticed that the outer edge of the front right(passenger) side tire seems to wear more than on the left front tire.
The XJ drives straight though. There's no pulling. And the tires have ~40,000 miles on them so the wear isn't excessive but it is noticeable.
Any ideas? I grease all the greasable areas at least once a year.
What are the symptoms of a bad control arm bushing?
Thanks,
MAP
Thanks,
MAP
