quick D35 question
.hendrix.
i have a '73 amc hornet along with my jeep. will D35 one piece shafts work in the hornet's amc-15? I recently disintegrated an axle bearing and bent the wheel hub in the process of pulling it off. help me......
Hello HX, from a severe laymans perspective on the hornet vs jeep axle swap is probably a no go. sorry to hear about the dismount problems that put you here.
hey, will the rear window from a 73 pacer fit in my xj rear hatch?
probably not.
There's actually a chance that it might.
I can't confirm that it will, but from everything I've read the AMC-15 and Dana 35 are very similar axles. If you have a JY that is local to you and does a 30 day warranty, I'd suggest finding a Dana 35 under a Jeep there, pulling the shaft and seeing if it works. At the very worst, you're out gas money and a couple hours of work. Who knows, maybe it swaps right in without any issues.
The AMC-15 has the same 5 on 4.5 bolt pattern as an XJ/YJ/TJ Dana 35.
The AMC-15 is basically just the pre-Spicer/Dana version of the Dana 35. Apparently AMC sold tooling to Dana and the 15 became the 35.
Explains alot about why a Dana 35 looks nothing like any of Dana's other axles, and for its size is generally a lot shittier than any of their other axles.
Just goes to show what a POS the D35 is, they only used it Hornets with the I6, all the V8 Hornets had AMC-20s.
