Question about Rear Axles
read the tag that is bolted on with the diffcover bolts..also so C8.25 has 3 inch tubes and the dana 35 has like 2.5in or 2.7's tubes i believe, basically the 8.25 will look beefier..HTh
<Maier
If you take a hubcap off, you can also tell by the indentations on the ends of the axles. The D35 (and 44) have an indentation sort of like an hourglass or figure eight. The 8.25 has what I would describe as a rectangle with bulging ends, not pinched in the middle like the Dana.
