Yah... While I do not remember the actual metric size, it was just a matter of using the drill bit as a ream to open the hole in the sensor. For sure a different part from yours. Glad to hear it is in. Be amazed at how much easier it is going to be to get the timing right under boost conditions.
So, a short note here on ignition timing under boost conditions. The rule of thumb states that you remove one degree of spark advance for every pound of boost. Funny as it may sound, my ignition map almost matches this rule. It is a fair starting point at any rate. Actual values will depend upon the compression ration of the particular engine being fitted with a compressor.
Here is the map I am currently operating with:
[/URL][/IMG]
It may not be perfect, but it does work... The load side is in Pounds per Square Inch, Absolute. That makes the 22 value at the top a reflection of 7.3 (22-14.7) pounds of boost at sea level. If I were to actually go to sea level, this map would require editing to reflect the actual performance. As it is, it is a fair compromise. The AEM F/IC operates in the same fashion as the stock PCM. At ignition on, zero RPM, the F/IC takes a snapshot of it's built in MAP sensor. This establishes the starting point for both the ignition and fuel maps. Once the engine is running, the F/IC goes dynamic.
Ideally, there would be an small bit of electronics that compares the output of a one bar MAP sensor to a preselected value. The circuit would then shift the maps from "A" to "B". The purpose of splitting the maps into "High" and "low" altitude versions is resolution inside of the individual maps. It is obvious that if the pressure range is reduced, the control over the ignition is improved. Unfortunately, I was not able to get the voltages needed so as to design and build this circuit. Here, in Colorado, we have to be prepared to go as high as 14,110'. I pretty routinely take family from out of town up to the top of Pikes Peak. Having a compressor on board lets my Heep scoot right up the hill.
So then, this map accounts for running from near sea level to the top of the Peak plus a small safety margin on the high altitude side.
