rav
- Albany, NY
I will try to post a pic of that setup in a few minutes.
FWIW, I'm not a huge fan of the blow-through throttle body and blowoff valve setup. But that's just me. Otherwise that's a nice clean setup.
Cut into the hood tonight. I also took out the hood vents I had since they hung down an inch or so, I will replace them with something else, not sure what yet.
Good news is, everything fits. I put in the charge air pipe to test and it fit perfectly.
All that is left now is to finish up the compressor intake manifold and to fabricate a couple of small brackets.
what tool did you use to cut it? Can you post the dimensions from the center indentation? It came out nice.
Would something like this work?
I know you want to have a y pipe for the bypass for your application.
Found this awesome video of a M90 in a grand cherokee. Too bad we don't have the same real estate in the hood:
https://www.youtube.com/watch?v=M4tMozlNS1E
Minor rant: Am I the ONLY one who swapped the compressor pulley for a 6 rib? Every single one I've seen videos of has the Thunderbird 8 rib pulley still on.
