IMO, what is happening here is why I recommend professional rebuilds of the compressor prior to installation. With the rebuild, you get a couple of guarantees. First one being that the compressor will actually pump at the rated output and the second one is the
peace of mind you get knowing that all of the bearings and seals are solid. Nothing can ruin your day faster than a compressor failure when you are away from home. It is a Show Stopping Event.
Plus... Places like
https://jonbondperformance.com/ offer a service where they can add a coating to the case and rotors that improves the sealing over stock. Some OEM manufacturers (Jaguar comes to mind) specify the coating on their OEM parts and, as a result, get remarkable amounts of boost. I believe that the Jaguar delivers 13 pounds of boost to their 4.0 Litre inline 6. Intercooled of course... The aftermarket for Jaguar does offer pulleys that take the Jag to 17 pounds of boost. An M90 feeding a 4.0 Litre...
To my way of thinking, spending the cash up front beats spending it in a crisis situation.
This is not a crisis situation, it is just that the compressor is not living up to it's potential. This is, trust me as I have gazed upon it's undeniable beauty, a very clean installation indeed. And it does have the potential for so much more as the Harmonic Balancer can be changed out from the 6.375" stock diameter to the 6.72" performance version. This makes for a substantial compressor speed change which, obviously, directly translates into increased boost.
One of the nice things about superchargers is that you can make mechanical changes that are, in of themselves,
relatively inexpensive and easy to perform that have the potential to completely alter the performance to the vehicle that compressor is fitted.
