cencal96xj
- Nipomo, CA
You mean reinforce the lca mount or the shock mount?
Both lol
What kind of cutter are you using? Nice to see some Cad work on an xj. I agree with everyone on the strength concern, perhaps you can make up some beefier LCA mounts with that shock tab design integrated in.
whats everyone's thoughts on truss vs. sleeve's for the front d30?
Oh and I finally renewed my membershiparty:
http://www.artecindustries.com/TJ-3044-HD-Lower-Control-Arm-Brackets-pair_p_372.html#tab-2
About to order these. They look like pure beef.
Remember those have the adjustable slot and not just a hole for the bolt to go through. Might make it a pain
Just get some poly performance lower CA mounts, they are cheaper, local, and you know people that can get you a deal.
That is what I have on my XJ, they are the 5 degree driver/passenger ones. Dennis welded them on "upside down" for built in protection.
Aside from that, you can get a "cam bolt eliminator kit" that is basically a cam bolt washer with a dead center hole. Those washers are typically thicker than regular washers.
