Sting25
twitter.com/cmchadwick
- Wheat Ridge, Colorado
I want one.... Ever since buying the house I have wanted a pickup that is just SWEET.
they look photoshopped. if you look at the flag in the right side attached to the garage you will notice the same thing in all the pictures...
Same color as the grime around the timing cover gasket Phillip. Speaking of color, hmmmm, Penzoil.
is the crank nose tore up or is that just some gunk on it?
Gunk. This engine is....... very well insulated with gunk!
Shoulda taken it for a power washing before starting these projects..........
Yeah, it does have the dreaded "Penzoil" varnish and a very light crud buildup but overall, it's pretty clean inside considering. I took a valve cover and oil pan off another 4banger I had a while back for a guy needing 'em for his YJ.... the valve cover had a "goo mold" of the rockers and weighed several pounds more than it should...... I'm happy with the varnish. :smile3:
Good man! What did you use in it, and for how long?not on my watch!!:conceited
If you are interested in replacing gaskets and seals, go ahead and clean out the residue. I kinda feel xj-grin is on track with that old-school rustproofing.
Kinda purdy now..... :thumbup:
I imagine it is, in a back country, Arkansas cousin sort of way...
Indeed. A set of these are going on some mudflaps next:
you "noticed" a case of death wobble?... you may have been warned! :dunce: Glad you didn't end up in a ditch! I figured it had to be the tracbar or similar, since I knew the balljoints were good, and didn't feel too much play in the tie-rod ends when I swapped the front end in...
