Drivetrain is in for the last time (hopefully
Whoever machined the flywheel I purchased new the first time, drilled the bolt holes wrong that secure it to the crank. Ran over to advanced to grab a new one and will return that one tomorrow.
Made a new indexing pin for the D20 as well. Chopped a grade 8 bolt down and drilled another 1/2" hole in both the adapter and the t-case. Should be all set now.
Bolted everything together and dropped it in. New clutch, pressure plate, flywheel, hardware, etc. etc.
Here's what it looks like now after clocking the D20...
And just for ****s and giggles, I threw in my winch to see how close the clearances were to my harmonic balancer. Plenty of room
On another note, I tried mocking up the bracket for my slave cylinder kit I bought from Novak. Seems like it won't work for me as the bracket hits the floor. I'll probably just end up modifying it to make it work.
This week I'll start working on the mid-rail stiffeners (3x3x.188" angle iron) and start the crossmember.
