Project Geosynchronous Orbit
Amazing how stable the video is, Go-Pro?
Yup. It was on a suction cup mount at the front of the roof. You can see it in the group picture of us.
Banged out a t-case skid over the weekend, and braced it back to the frame rail as well as a small gusset in hopes that it will also double as a traction bar mount. We'll find out. The 1/4" plate bolts on, just need to countersink the holes and get hardware.
Also used my torch to knock out a d-ring tab, then ran out of oxygen. Did one in less than 2 minutes. Screw using an angle grinder for that.
Adam also made some gaskets for me and resealed the NP435/D20 and the adapters inbetween. HUGE help, thanks dude! We also figured out what was causing 1st gear to grind, it was a bolt that was 1/8" too long. Trimmed it up and it's as quiet as a straight cut granny gear should be :laugh:.
Should be getting my Viair stuff as well as my traction bar stuff this week so I can get it all done before NACfest.
So im guessing the hoop wasnt too tight of a radius? Looks great, almost like you had a clue what you were doin :thumbup:
Colin said I could have the MJ if the transmission leaks again.
Use crisco instad of gear oil for the untimate no leak solution
I wonder if Adam's D30 pinion bearings will last longer if he tries this.
That hill sucked. It tried to eat my A Pillar.
Irony. Right here. :D
Turns out this thing sucks so Colin gave it to me over the weekend.
:laugh:
Turns out Chris drives like a vag so I had to take it back. He was too scared to shift to second gear :D
Haha, so true.
For those who weren't at NACfest, Colin's MJ did catch on fire at one point due to an oil leak.
Yup...I kinda figured someone was going to remember that quote :laugh:
Wasn't too bad though, Bill put it out for me within a second or two. Just goes to show that EVERYONE should have a fire extinguisher in arms reach from the driver's seat. There really is NO excuse.
:laugh: That was funny. Hows your rear wheelwell? :D
its just fine. waiting to get covered by some tube :)
Just updating the thread with the final modifications I finished before I wheeled it at NACfest. Thankfully nothing broke except a sidewall in an MTR (plugged and still holds air) and a small engine fire that was put out quickly (oil leaking on the exhaust).
Here's the traction bar I made. Lower link is 2" x .250" DOM, upper is 1.5" x .250" DOM. 7/8" heim at the shackle, the rest are poly bushings. I bought the Ruffstuff traction bar kit and it worked out perfectly. It's actually on sale right now and I highly recommend it.
Here's the OBA setup. Pretty much copied Jeff (XJEEPER) in this aspect as he seemed to like his. I LOVE this setup. Works perfectly, I would just have to add a larger tank or a second compressor in order to run air tools.
Tank and compressor mounted in the bed.
0-200PSI gauge and on-off power for the 85-105PSI VIAIR pressure switch.
Left-right - Tank, Air valve, 125PSI check valve, plug, Gauge, plug, 85-105PSI VIAIR pressure switch, plug
Bilstein 7100s mounted as well as the limit straps. I may or may not move the straps, not sure I like them yanking on the thin shock tower.
And the d-ring tabs I torched out of 1" plate.
Finally here's an overall shot of the finished engine bay, interior, and exterior.
This thing is still a work in progress however, as I'm currently building a gottrikes bender and will be caging it in the near future. Following that will be getting the winch working as well as some t-case shifters.
still has no lights and shitty sidewalls other then that its pretty sweet
