started cutting the square tubing for the new spring hangers for the 14 bolt
i need to figure out how to get the old bushings out of the leaf springs. last time i did a set of leaves i had a good ole bushing bbq, but i know thats not too enviro friendly. ill probably have to pay money to get them out again this time
i also need 1-2 sets of stock xj shackles. the shackles on this truck were toast, so i need to get some new ones and the xj stockers are actually the exact same thing. i took two sets to the scrapyard before i bought the truck...go figure.
how much does sheet metal go for these days? i think i have a dumb idea that i might try to fix my box sides first myself to see how it goes. i know sheet metal is tough, but my welder seems to do a great job with it. they sell full replacement sides for the j10 boxes, but mine isn't to bad so im thinking i can do a little sheet metal work to fix it. i want to try one small part on my own to see how it goes, if i flub it up a little it should be able to be fixed...if i flub it up a lot, then i'll be able to just buy a full replacement side...seems like a good enough reason for me to try it at least!
the plan for now is to get the axles under the truck...front is already there...back should be done next week. then i am going to drop the engine on the frame, hook up the radiator, change the oil, prime the fuel system and start that baby up...at that point i'll have a lot more peace of mind that this motor will run once the whole thing is back together...let the fun begin
