- Painted Hills, Indiana
That red looks familiar. Like it.Gloss apple red
Took it through carwash today at lunch to get all the grinding dust and sparycan settling dust off the rig....needs a little more seam sealer up top. Looks damn good now.
Seam sealer worked awesome on mine for a while, but the roof had just enough movement to crack it and leak a little bit. I'm going to put some silicone over the seam sealer since that is a little more flexible.
If you have any overspray on the paint that didn't come off in the carwash, pick up a clay bar, it will pull the overspray right off of it.
you gonna slap some stickers on it and write it off as a business expense?
A little water never hurt anyone
I used red RTV on the ugly trucks sunroof gasket. it's the only thing that stayed flexible and adhered. It still doesn't leak and I did that 8 years ago.Seam sealer worked awesome on mine for a while, but the roof had just enough movement to crack it and leak a little bit. I'm going to put some silicone over the seam sealer since that is a little more flexible.
Gov't pays me to wheel......
I can vouch for the no leaking.... And i heard the body twist so bad last month i thought the back window was going to fall out
SWEET!! How is it for head room?
How is the head room for the driver.
I am told the center console gets in the way.
She much prefers a bench seat.
