kmanxj5050
- Reed City Michigan
Re: Project "Something Awesome"
Did you have to get pulled to the parking lot again?
add "raise rear shock mounts" to that list.things i learned:
- pete (whitexj98) is pretty handy with a high lift.
- i need to replace my E-fan.
- gears and lockers just became priority.
- this no start issue i have when the jeep gets hot needs to be fixed.
i dont recall having to get pulled to the lot. just to flat ground. :bawl:Did you have to get pulled to the parking lot again?
MUDDDDD!!!!! I thought you didn't play in the mud??
i always happens when hot... and i can push start it just fine. specifically it happens when wheeling. i would guess the clutch is generating more heat in these situations. or at least it did yesterday. but when cranking hot, it had no spark. its not throwing a CEL, but pete had a scan tool on hand and it seems to be the CPS. i replaced it today.Oh yea that's right, that was the plan and then it started. Still that's a weird issue.
im sure my cap, rotor, wires, and plugs all could use replacing.
