I see, there is no structural rustJeepFreak21 said:He means, maybe you had to cut away more of the structure than you thought (on account of the rust).
Billy
Billy
BrettM said:with that much wheelbase and width, I would increase the lift height if I were you; the breakover angle is going to kill you. also, it doesn't look like you turned the knuckles, when you get a driveshaft bolted up to that low pinion you will see how much this is needed. as I've mentioned many times before, plan on hydro-assist (or a panhard).
oh, and I will be making fun of that bumper, just to warn ya :laugh3: I like mine where it's just barely in view from the driver's seat.
Full width chebby dana 44, uknown backspacing, but they have as much backspacing as possible without interfering with the steering. No plans for hi-steer, I have a nice crossover steering setup that keeps the tie rod up high.baseballneal86 said:What backspacing are you running on those wheels?
Also, I didn't see it listed in your post, but I'm guessing that is a full width Chevy D44?
Any plans for hi-steer?
it is so awnBrettM said:moonrocks the 25th/26th![]()
davidt said:it is so awn, you want to do some other local trails as well? How set up is phil? Anybody else coming?
