CRASH
- Foresthill, CA
:wierd:
CRASH
CRASH
Jeff 98XJ WI said:So, you coming to Apple Valley? I cobbled together the upper control arm from my two old lowers and a piece of additional tube with the three pieces welded together. I need to get a fresh piece of tube threaded and was thinking you had the threading connection!Jeff
JerryV said:I will not be able to make Apple Valley.
I was hoping that the upper wasn't two pieces of tube butted together and welded. :hang:
I do have a threading connection and that would not be a problem. Price is right too.
Jerry
There's nothing wrong with welding the tube. Just be sure to cut a good camfer into both pieces so you get the weld into as much surface as possible (you want to create a big "V" to fill with weld). The knock on butt-welding tube comes from people who just put two square edges together and then weld "around" the outside. That is basically just creating a section of tube that is very thin walled (just the thickness of the weld)Jeff 98XJ WI said:Actually, why exactly is my welded tube so bad? Many folks run tube with welded in bungs in the ends and that's ok. What's wrong with a good weld in the middle? There isn't any real side load on this link. Many rear axles use butt welded housing ends. I don't intend to leave it in there as it was more a test piece to get the bugs worked out, but really, what is wrong with it? Oh, I adjusted lengths a bit last night and think I'm ok at 36" lowers and 34" upper. I would like to tilt the pinion up a bit more, but that takes away from caster, so I'm not going to. I should have built in a little more pinion angle during the d44 build...but I was sitting lower when I built that too. Jeff
Did you get my email?Jeff 98XJ WI said:So kid, what's your progress report?
Bite me.Jeff 98XJ WI said:I'm driving mine.Jeff
Jeff 98XJ WI said:I should have built in a little more pinion angle during the d44 build...but I was sitting lower when I built that too. Jeff
kid4lyf said:Did you get my email?
Got the front axle in, measured and welded up the LCAs, installed them and everything was good in the world.
Then I looked at the DS.
It'll hit the x-member LCA mount after about 2" of droop.
Apparently, clocking the TC is a needed mod with the URF 3 link without some inventive mount placement.
Hopefully that will solve the problem.
Ready for the UCA mount.
Then things really get fun.
Starting the rear, Fox air shocked, 4 link.
Yeehaa
Bite me.![]()
I see from the pics that your x-member UCA bracket is wider (to mount the JJ) than the post that holds it. Will the bracket clear the DS when installing the x-member or do you have to put in the DS after the x-member is in place?Jeff 98XJ WI said:There must actually be more room in some respects compared to Andy and Jes's manual tranny's because I am using a larg Currie JJ at the crossmember end and it fits with no problem. I can't remove it's mounting bolt without dropping the crossmember...or cutting a hole in the floor though. Good luck, Jeff
kid4lyf said:I see from the pics that your x-member UCA bracket is wider (to mount the JJ) than the post that holds it. Will the bracket clear the DS when installing the x-member or do you have to put in the DS after the x-member is in place?
I guess you have a point there. With everything that's now involved in dropping the x-member, what's adding one more thing?Jeff 98XJ WI said:Well, I don't know! I put the painted crossmember up with the JJ in place and tightened down prior to installing the Driveshaft. I know it took a little contorting to get it in position near the exhaust with that hanger. I just went out and looked and would have to say probably not. Maybe without the bolt for the JJ in place, but I don't think the bolt will clear the driveshaft. I hope not to remove the crossmember very often since it now holds ALL the suspension mounting points...the one downside to this setup. Jeff
kid4lyf said:I guess you have a point there. With everything that's now involved in dropping the x-member, what's adding one more thing?
I AM definately going to cut out an access panel in the trans tunnel to be able to get to the mount from above. The idea of dropping the whole thing down to service that one joint is out of the question.
I'll be cutting roughly a 6" X 8" hole so I can get at it easier for any servicing. Especially if I use an RE SF joint there instead of a heim. The RE joints need occasional retightening.Jeff 98XJ WI said:If you simply want to pump the joint with grease, that can quite easily be done from below. If, however you want to REMOVE the joint, then a small hole would need to be made in the floor board for the bolt to pass through in order to remove it from the mount. Jeff
Guess you're advanced now :worship:Jeff 98XJ WI said:Hey, who moved my thread!?![]()
kid4lyf said:I'll be cutting roughly a 6" X 8" hole so I can get at it easier for any servicing. Especially if I use an RE SF joint there instead of a heim. The RE joints need occasional retightening.
Guess we're advanced now, huh?
Really?Paul S said:I can't believe you're going to cut a hole in your floor, this Mod. is so not worth it.
paul
kid4lyf said:Really?
A half hour (at most) to give me the ability to service the rear UCA mount without having to remove the entire x-member?
Worth it to me.
joke P Pronunciation Key (j k)Paul S said:No, I mean the entire hidden 3 link isn't worth it if you have to cut the floor![]()
Paul
