SgtBenny
- Mt. Laurel, NJ
Good morning.
I followed the "NP 231 Speedometer Gear Install Writeup" exactly but when I took it for a drive my speedo was not registering. I opened it back up and put the old one back in and it worked fine. I figured I'm just not smart enough so I took it to a mechanic buddy. He installed it and same thing happened. He looked at the size difference between the factory gear and the 30 tooth gear and there is a significant diameter difference between them. The factory gear is much larger than the 30 tooth. He seems to believe that the teeth aren't touching the internal gearing.
I confirmed the part number and it is right. Any ideas?
I've got:
The late model 96XJ with the 8.25 29 spline rear.
4.5 RC lift
33" tires
Odds & Ends.
Thanks for any help.
I've got:
4.5 RC lift
33" tires
Odds & Ends.
