power windows
HilltopXJ
NAXJA Member #950
Eagle Point, OR
None of my windows are working on my 88xj 4dr. Checked breaker on fuse block it has voltage. then I checked voltage at switch, it has power. Did I lose the ground maybe? when I did a search someone said that the door locks and windows have the same ground is this true? My locks are working and not my windows. All the motors seem to work fine.(had to jumper them to get the windows up). where does the power wire from the breaker go? It looks like it heads up under the dash somewhere. Is there a junction or a relay under there. Got some spare switches from the junkyard doesn't seem to be that either. Anyone with some Ideas would be helpfull..thanks
