It's easy to take off the panel. Make sure you don't hang it by the manual door lock and latch cables after you pop it off...bend those at all and your manual door lock won't line up and will be stuck on open. I recently replaced my power window module and unfortunately bent the cables and it stayed unlocked no matter what I did. Fortunately, I discovered this by accident. I ended up disconnecting the lock cable vs. buying new ones since I have power door locks and they still operate properly, and I never used the manual lock anyway.
But it is easy to remove the panel.
Nay
