Mastodon
- Northern VA
I was wondering if anyone knows the fix for an inoperative driver side master window switch. This is on a 2000 XJ.
The switch works every now and then, and sometimes when I flip it the automatic roll up/down feature activates. It often will continue to roll up or down causing the teeth to grind until I flick the switch in the opposite direction.
I believe this to be an electrical issue pertaining only to the driver side door window switch, specifically related to the automatic roll feature (the panel controls the other windows with no problem 100% of the time)
I tried the door panel splice fix to no avail, I do not think the problem is the commonly reported window regulator, as my window has never dropped.
The window is currently stuck 2/3 of the way up, I need to get my car inspected tomorrow (in my state your driver window must roll down, but does not have to roll up) any help is much appreciated.
The problem I am describing is the same as post #4 on this forum: http://www.doityourself.com/forum/p...-2000-jeep-cherokee-window-switch-broken.html
