Paul Airhart
- La Quinta, CA
I agree, it should be treated. But that should be in a separate plant and used for landscaping irrigation. I would not want it dumped into the water we're going to drink.
Read the post. The answer is there.?:anon:
Water wasting, in all of its forms is going to kill us. The Colorado river supplies a lot of water out this way and it doesn't even provide enough water to reach the Gulf of California anymore. LA gets a chunk of their water from the Owens River valley, supporting all the farming in the SFV by stealing the water that was used for farming the Owens River valley. Wasting water because you think the state wastes even more is foolish logic.(And, if you're going to kvetch at me for 'wasting water' - back home, all of the storm drains ran to the water treatment plant. Why don't they do that out here?)
You're trying too hard. Swapping engines does not necessarily entail removing smog equipment. A newer engine will make considerably more power with all of it's smog equipment than the low tech smog equipment currently choking 70's cars.and technically just because you dont have to smog it doesnt mean it's not illegal to pull off or alter smog equipment, they're still bound to the same rules as a newer car. So technically you're advocating breaking the law, and i award you one demerit.
See? how do you like it?![]()
but my point is why would you need a smog exempt vehicle to do a motor swap if you were going to abide by the law? If you weren't breaking any laws you wouldnt need a smog exempt vehicle as it is perfectly legal to swap a newer more powerful motor into an older vehicle as long as it has the proper smog equipment from the donor vehicle. And technically if you swap a motor from a 91 mustang into a 74 bronco, you need to bring it to the smog ref to be inspected, and you'll now have to smog it as a 91 mustang forever.You're trying too hard. Swapping engines does not necessarily entail removing smog equipment. A newer engine will make considerably more power with all of it's smog equipment than the low tech smog equipment currently choking 70's cars.
i think it's technically the law, but it's like marijuana at this point, i think for the most part it's overlooked unless you're doing something blatantly over the top and wrong. Like if you got caught street racing and nearly run over a kid and a cop sees it, he may hit you with everything he has.I can agree on that. If I can swap a different engine in and get better emissions than current, but I lose some of the equipment, than what's the harm?
Are you sure that you'd have to smog the vehicle if you swap engines? I have a 73 F250 and I'm pretty sure I wouldn't have to show it to anyone if I swap engines around. But then, I haven't looked too hard at the regs yet since an engine swap is a long ways off for me.
Probably because to many goofballs dump toxic chemicals into the storm drains here.
The logic you used in your initial post sounded like you were essentially saying you wasting water is no biggie because the state does worse.
Don't mind me, living where there is no water has made me touchy about water...![]()
I'm really just busting your balls because i know you like to do the same when people post up about illegal mods. I personally think it's all BS anyways, aside from the sniffer test. Clean air is the only thing that matters IMO, who cares what road we take to get that the end result. The rest is bureaucratic BS.
Amen. My afore mentioned 80 CJ7 with the 94 LT1 swapped in failed due to bureaucracy. I performed the swap before living in California, and it failed because it had a modified ECU, the fans were on a toggle switch, it was missing the smog pump, and it had two cats (instead of one...the Camaro the engine came out of had a 2 into 1 exhaust with 1 cat). BUT it blew NOTHING on the sniffer. Zeros across the board. The ref even joked with me, that all I had to do was fix this stuff without worrying about getting it to run right. Thanks, bro.
I think on older cars, if it passes the sniffer, it's good to go. I see so many older cars belching smoke that should be sidelined, but my cleaner CJ wasn't allowed in Cali because the ref didn't like what he saw. How about a smog law that just cuts down the bureaucracy?
Sniffer only and ditch the visual? I'm all for that as well!
Seriously. Isn't the tailpipe emission all anyone should care about? I've never understood these insane visual inspections. I had a car fail for a non-carb approved homebuilt air intake. WTF does it have to do with emissions?
