POSJ's SWB Build
POSJ
Not that it really matters at this point if it's SWB or LWB...
Besides replacing the whole rear frame section, has anybody actually plated theirs? What did you do about the stiffening bead above the wheelwell? I am going to try relocating my spare tire under my flatbed and since I have the bed off I was thinking about plating it. Prior to cutting out the crossmember.
Re: Rear frame, SWB
it's pretty stout as is. Unless you need to attach stuff to it I don't think any strength gains would be worth the effort and weight.
Mine was halfway rusted through and still took a beating .
The front needs help though.
Re: Rear frame, SWB
Since you have your bed off, and I saw part of it already, can you take pics of how your fuel tank is mounted. I know factory is mount from frame to bed bottom.
Re: Rear frame, SWB
Hope this helps, just box tube bolted to stock straps with stock skid. I'm going to change it up and make it so the box tube stays with the Jeep if the bed is on or not.
Re: Rear frame, SWB
This might end up being my build/rebuild thread...
Broke the rear window yesterday, lawnmower threw a rock. Not happy.
Anybody know where to get one?
Re: Rear frame, SWB
Try comancheclub forums? If you were in Cali I have a non slider that I could part with.
Re: Rear frame, SWB
PM shortxjdoug
he has a broken slider, but I'm not sure which side he broke.
The glass is not available. unless you find a used unit you're SOL.
it's also not a straight piece of glass. It's curved, very slightly. Enough to make a flat piece not fit.
Re: Rear frame, SWB
PM shortxjdoug
Ok thanks, yeah the center section is already plexiglass. If I end up replacing the left side with lexan or plexi I'm going to do all three and tint them before putting it in.
Rear frame, SWB
Thats the one i broke too. Ill double check, but im pretty sure i only have the center slider and the pass side
Re: Rear frame, SWB
The link posted above is the only style I could find for a replacement tyler. I looked into putting a new one in when it got painted. I was probably the most hated thing I had to do was cut that plexi for the slider. this was only after a week solid of looking for a "nice" replacement. One of the things that stuck out like a sore thumb to me once it was done. I could not justify putting a solid pane window in there. Sliders are soooo nice with the wing windows.
At least that rock didn't get the paint!
Bronze.
Re: Rear frame, SWB
Soooo, I finally got the window in today. One thing I am not thrilled about is that it is not factory style. You have what is pretty much 3M double sided tape between the window frame and the body, you then drill six screws through the pinch seem and the window frame to mount it...trying to figure out if I want to go this route now.
Re: Rear frame, SWB
You can use normal windshield adhesive to hold it in. Make spacers to keep it centered in the frame. I used framing shims from Lowes. Once installed hold it in place with 2" painters tape and let it sit for a day or so to fully cure. I did mine this way and it has been fine for 6 years.
