- Nashville, TN
He has one more available...brand new still in the box...$350 he's asking for it.
when you get into a head-on collision, that hi-lift is going to rip out of the plywood, come flying forward and decapatate you and your passengers...
please move that lower behind the seat, at least?!
jus' sayin..
-Brian
I'll bring back an old thread...
This is a drawer made by a company called TruckVault. It was built to specifically fit the XJ. They make them for all sorts of SUVs.
I got this one used off a guy on Craigslist for $100. When I opened it up, there was a Teraflex 1 1/2 inch lift kit in it (coil spacers and rear axle shackles!)
The part on the far left, where the fire extinguisher is mounted is a lift door to access that little indent in the side molding. Just large enough to keep a pair of gloves, jumper cables, and a funnel.
It didn't come with the cargo net. I had an extra from a ZJ and just screwed 4 OEM tie down brackets from a wrecked XJ.
Score on the truck vault.
I'll say...not only was it cheap, but he installed a brand new lock he had for it since the old one was bound up, AND he had a Tera-flex 1.5" shackle set inside he sold me for $5 more, AND when I called for directions to his house, he was less than 2 miles away from my house!
O Brian O Brian I totally agree !!!!!!! I have told my head- on story here more then once so I won't again, but w/o having done it he has no idea what the sudden stop forces are. That jack will pull thru that wood so freakin fast you would not believe it....even at 30 no less freeway speed. please stop driving till you get the jack somewhere else!when you get into a head-on collision, that hi-lift is going to rip out of the plywood, come flying forward and decapatate you and your passengers...
jus' sayin..
-Brian
I'll play... the center section hides away 2 10" subwoofers.
Pics from when I first built mine. I wanted to add a place to put the Viair and Tank. It's bolted through the floor, the fire ext is on one side with a Flashlight mounted on the other.
Plenty of room inside for parts, oil, Straps, tools that don't fit in the small tool box. With the tool box I wanted to be able to pull it out when I needed without lifting the lid.
It's been in for a couple of years now and the MDF is starting to show wear, looking at some of the pics here I may have to rebuild soon.
I also have straps going to the factor cargo mounts that I put on when wheeling, Just not sure how well the latches were going to hold in a roll over.
Here's mine. Basically just a shelf that I slide stuff under and can tie stuff on to. A change I recently made to the original design was to make the front flat. The first one one, had the front angled to match the rear seat. That was dead space so based on this thread, I cut the front straight down and now I use that area to store spare shafts. I get to them by flipping down the rear seat.
The requirements were:
1. I don't want the stuff to hit me in the head if I roll
2. I want to be able to get to the stuff easily
3. I wanted the stuff out of the way, day to day
4. I want to be able to unload everything easily
5. I wanted a flat area with tie downs for "other stuff"
6. Cheap (used an old desk and scrap wood)
7. Simple
my question is... is your wood screwed or bolted down to the floor? if not it will still get you in a roll over.
