Pivoting Leaf Spring Perches ???
turbobaja1835
NAXJA Member #1299
I was looking at these on the BC Bronco page for the rear suspension. It seems to me this may be a good way to get the rear suspension of an XJ to catch up to the front coil suspension without going to the extreme of doing a coil conversion in the rear. My first thought was, these things are going to break though but I imagine if you build them right they won't. Also making sure that they won't bind, in which case a limiting strap may be in order. Anyone running anything of this type? Any input?
Thanks, Joe
http://www.bcbroncos.com/ (Under the rear suspension section.)
Also how much more flex do you think this would give you over a stock perch setup?
