Parts from 1988 Laredo in Eastern Massachusetts
Jay Welch
Updated 10/06/04
If a part is not listed below, I do not have it.
Be sure to reply via the email [email protected].
I can send you a list of everything I have with pictures. I can also sent the Word document with the inventory. It might be easier to read.
Minimum parts shipment is $15.00. There’s no minimum if parts are picked up.
Payment for total must be made via money order or cash. Be sure to fill out the front of the money order completely. Personal checks will be returned to you.
I will only use UPS to ship the parts...sorry no exceptions. Your cost to ship will be exactly what it costs me to ship. You will need to get an estimate from UPS for shipping to your location. You can then decide if it's worth your while to pay for the shipping. Estimate the approximate weight and box size necessary and estimate from my zip code (02351) to your zip code.
The first person to commit to buying a part will get priority. Please remember to notify me when you send the payment. I’ll keep you informed of all status.
If I take the time to reply to you please return the courtesy by replying as to whether you want the parts or not.
Thanks,
Jay
Located in Abington, Massachusetts 02351
Email: [email protected]
XJ PARTS LIST
Repair Documentation
• Factory Service Manual on CR-Rom - $10 Email for a listing of file names on the CD
• Haynes Repair Manual, Jeep Cherokee 1984 thru 1997, excellent condition - $10
Rear Deck - White color
• Rear deck lid, excellent condition with glass & defrost - $15 - Pick up only.
• 2 rear deck speakers - $1 each
• License plate light - $1
• Rear deck striker - $1
Hood - White color
• Hood, excellent condition - $15 Must be picked up.
• Hood support rod - $5
• 2 hood hinges - $1 each
• 2 hood tension spring assemblies - $5
• 2 hood latches and rod, no cable - $5
• Hood front center hook latch - $2
Doors - White color
• Complete set of Laredo cladding for bottom of doors - $30
• Rear door (bare), power window style, left side, excellent condition - $15 - Pick up only.
• Door check strap (New), left front door - $10
• Front door (bare), power window style, right side, bottom is excellent, 1 small hole behind Laredo trim..easy fix with mig - $5 - Pick up only.
• 3 chrome door edge guards, 2 front, 1 left rear - $5
• 4 door latches (from door) - $2 each
• 4 door latch strikers (on post) - $1 each
• 2 interior door light switches, rear - $2 each
Misc Body Parts
• Windshield wiper cowl cover, white, excellent condition - $5
• Fender flare, left rear, good condition, gray color - $5
• 4 hard rubber bumper boobs, front and rear, excellent condition - $1 each
• Front bumper end piece, left side (no stud) - $1
Lenses, Bezels, Rings etc
• Chrome headlight bezel, larger piece, right side, excellent condition - $5
• Front clear directional housing assembly, right side, excellent condition - $5
• Front chrome side marker bezel, smaller piece, right side, excellent condition - $5
• Headlight retaining ring, right side - $1
• Headlight bucket, right side - $1
Glass and Frames
• Front vent window and latch, right side, excellent condition - $10
• Rear cargo area glass, left and right side, excellent condition - $5 each
• Rear door main glass, left side, excellent condition - $5
• Small fixed glass for rear door, left side, excellent condition - $5
• Front flip out vent window frames, left & right side - $5 each
Exhaust
• Exhaust manifold, no cracks - $50
• Catalytic converter - $20
• Front pipe donut (New) - $2
• Exhaust hangers - $1
Fuel
• Fuel tank - $20 - Pick up only.
• 2 fuel tank straps - $5
• Charcoal fuel vapor cannister - $5
Miscellaneous
• U-Haul Class II trailer hitch (350 lb tongue weight/3500lb gross weight) includes 5 wire Jeep system to the common 4 wire converter and lighted connection pigtail, pigtail also includes second interface for connection to U-Haul brand trailers - $65
• Air conditioner refrigerant hose - $5
• 3 steel wheels - $5
• 4 chrome wheel trim rings - $5 each
• 1 black wheel center - $5
• 1 cooling tank cap and strap - $1
Brakes
• Brake master cylinder - $10
• Brake pedal assy and brake light switch - $5
• 2 parking brake cables - $2 each
• 2 caliper anchor plates - $1 each
• 2 front brake dust covers, not bent but a little beat where the hub meets them - $1 each
Accessory Brackets
• A/C compressor bracket, mechanical fan mounting hub and idler pulley assy - $5
• Power steering mounting bracket - $2
• Alternator bracket - $2
Interior – Gray and Charcoal Color
• Glovebox door and latch assemby, charcoal color - $5
• Right front chrome inside door handle/panel and switch - $5
• 2 head rests, gray vinyl, not solid type, style with the hole through the center - $5 each
• 2 chrome left and right rear inside door handles/panels and switches - $2 each
• Left and right seat recline handles, black - $1 each
Electrical
• Heater/AC blower motor and fan assembly - $25
• Windshield wiper motor and linkage assy - $20
• Heater/Air conditioner control and cable - $10
• Wiring harness - front section to headlights and parking lights - $5
• Wiring harness - sections for most of front door posts to rear deck/taillight areas. Don’t have under hood sections, under dashboard sections or the RR window harness - $5 per section
• Digital clock - $5
• Windshield washer reservoir and pump - $5
• 3 grab handles, gray - $2 each
Front Differential
• 2 front hubs, one has a very slight notchiness, the other is smooth - $25 for both
• Front axle disconnect vacuum motor, fork and gear - $10
• 10 front wheel studs and nuts - $5
• Steel vacuum line manifold for vacuum disconnect - $5
Engine
• Crankshaft damper/balancer - $15
• Knock sensor - $15
• Oil gauge sender unit - $10
• Temp sensor - $5
• Valve cover oil fill cap - $1
Transmission/Transfer Case
• AW4 neutral safety/backup light switch - $75
• Rubber transfer case mount for AW4 Transmission/NP231 - $5
• Trans and xfer case gear indicator lights/harnesses - $5
Steering
• Power steering box (known good part - was removed from my Jeep while troubleshooting a problem) - $50
• Power steering pump (known good part - was removed from my Jeep while troubleshooting a problem) - $35
• Steering box shaft with nice free u-joints, this section attaches to steering box input shaft - $10
• Steering tie rod - $10
• Steering center link - $10
• Steering stabilizer unit - $5
Suspension
• Stock lighter duty front sway bar, bolts, brackets and bushings - $5
• Stock lighter duty rear sway bar, bolts, brackets and bushings - $5
• 2 upper control arms - $2 each
• 2 rear suspension bump stops - $1 each
Rear wiper motor?
-Scott
Can I call dibs on the gas tank and straps? I just have to make sure that it will fit into a 96 no problem. I live in Sunderland, MA which is probably a little over 2 hours away.
damn, missed that last post. anyone have a gas tank they need to get rid of, let me know.
Email me at [email protected]. You can have the tank and straps. Even if it doesn't fit yours you might know someone that can use it.
I work in Hopkinton and can bring it to work for you. Might be able to get someone to take it to Athol for you and save you some more time and gas.
Jay in MA
