blondejoncherokee
- sacramento
First come first serve
jeep XJ 4.5 stroker short block only – stock rods and pistons
just the crank. Rob on here built this . I should be asking like 800$ for this thing. At this price I just want it gone and to cut my losses
I don’t want to hold it anymore – tons of flakes on this. Not one person has showed up
280$
renix era 4.0 head
30$
JKS front upper stud eliminators
brand new
put about 5 miles on them
35$ obo
front shock bar pin eliminator
brand new
35$ obo
alternator relocation kit for a renix,
puts alternator up where the AC is, need to remoce the AC
comes with shorter belts.
Worked awesome
alternator drilled out for bigger bolt, and brackets and extra belts for the shorter setup, with a spare alternator already drilled out, and multiple spare 77" serpentine belts, like maybe 4-5 belts total, and the spare alternator. Alternator is almost brand new
renix era
75$
Pair of Ruffstuff rear coil buckets
20$
dana 44 steering 1.5” .250 new rufstuff steering with parts mike TREs, the cure spacer, ruffstuff stabilizer mount
240$
RCV 30 spline hub gear for a dana 44 – to convert 19 spline hubs to 30 spline hubs
40$
wildwood brake proportioning valve
rear line only
works awesome when dialing in a custom booster/master on bigger axles...
25$
zip locker ARB solenoids with ARB switches (front and rear only)
30$ for all
borgeson steering shaft
175$
anti rock Pro Crack sway bar home made
1991 trooper torsion bar
ruffstuff heims on end links
½” plate for arms
130$ obo
derale dual pass cooler
power steering or tranny
40$
longer rear bump stops
made by rustys
one is a little banged up
15$
dana 44 covers with plate welded on and gusseting
10$ each
pacesetter header for 87-90 XJ
40$
WJ drop pitman arm
20$
280$
renix era 4.0 head
30$
brand new
35$ obo
brand new
35$ obo
Worked awesome
renix era
75$
20$
240$
40$
rear line only
25$
30$ for all
175$
½” plate for arms
130$ obo
40$
made by rustys
15$
10$ each
40$
WJ drop pitman arm
20$
