CAJJ93XJ
- Roseville, CA
ok so heres everything I got. I know its time for this jeep to go I just need some motivation. so if I get some people interested in parts I'll tear it down this weekend
:deep breath:
HPD30, sierra gear 4.56, aussie (probably broken)
passenger side nitro chromo shaft with nitro ujoint, full circle
drive side chromo is twisted so I put an ABS shaft with 760 full circle in it. still haven't broken it
teraflex knuckle, crossover 1 ton with bent tie rod
bent LCA mounts
bad pass seal, slightly leaky
ruffstuff cover
ball joints and bushings replaced last year. no DW
you can buy as is or I can fix the LCA's, seal, and aussie and clean it up real pretty, maybe even put on a new DOM tie rod for the right price
best offer as is
rear 8.8 setup for XJ with 4.5"-6.5" lift without shims
Yukon 4.56
Detroit full case locker
ruffstuff swap kit/ antiwrap perches fat ubolt kit
welded tubes
alloy shafts
dumb cclips and drums still. but I cant manage to hurt this axle
ruffstuff cover
I'll clean this up, change fluid, etc. I'm hoping for $800 this things sweet
T&T high clearance long arms and belly pan, newish JJ's and bushings with spare bushings
$700
NP231 with JB SYE no leaks, I'll change the fluid for you. never slips or grinds
$200
XJ front shafts x2
$25/each
Parts mike stainless brake lines really long like 22"
$60
rubicon express rear stainless line 18" I think
$15
D30 chromos loaded with new 760's full circle. very clean pair of shafts
$300
BRAND NEW KM2's set of four 35" km2's never mounted still stickers on them bought in march 2013
$1000
that's all I can think of for now.. I know theres more
:deep breath:
bent LCA mounts
ruffstuff cover
best offer as is
Yukon 4.56
welded tubes
alloy shafts
ruffstuff cover
$700
$200
XJ front shafts x2
$25/each
$60
$15
$300
$1000
