Parting out 98 Cherokee Sport SE WI or sell whole $1000 OBO
jeepcomj
wisconsin
98 Cherokee. just had motor replaced with junkyard motor....found out the oil pump is seized (sheared teeth off of distributor). Has good compression. I imagine it had moisture in the pump and was iced up. compression was 100psi in the lowest hole, 150 in highest. Engine has been dry/not ran for quite some time, and dry rings do not seal well.
176xxx miles on jeep.
4.0 motor has good compression could have issues, had bad oil pump $75
aw4 $100
np231 sealed output $250
d30 $100
C8.25 $100
3.55 gears
factory tow package. Mount for trailer harness rusted off hitch, but hitch is solid. $50 for hitch, $50 for plug and play harness
keyless with key remote 97-98 style $50
factory fogs (complete headlight harness plus switch panel and fogs. plug that in, you've got fogs) $150
good bumpers $50 each
cruise control $100
decent rubber on crap rims $50
good doors...minor rust on lower edge, but not bad can be easily cleaned up $75 each w/o regulators
nice front fenders $75 each
header panel complete w/o harness but w/ lights $100
nice liftgate...minor rust not bad can be easily cleaned up $150
good radiator $50
aux fan $20
stamped steel 96+ valve cover $20
all sensors - make offer
throttle body $40
intake $10
complete exhaust with 02 sensors and good catalytic converter, good hangars $150
complete Power window/Power lock harness will work deal with all regulators/harness to do conversion send me a pm
fuel tank (pump is good, doesn't leak) $50
dash make offer
steering column non-cruise $80
full set of matching key with all locks (front doors, ignition, glovebox door, rear hatch) $80
new starter $50
97+ conversion stuff
The floors are rotted out. Has a push button to start...haven't looked into that
1000 OBO on the jeep. All prices are OBO and do not include shipping. pics posted below
link to the rest of the pics
http://s248.beta.photobucket.com/us...r whole?&_suid=135749869730509604618293071834
the signal, or the corner marker? I am selling the header panel whole, but have spares of those.
They would be perfect for that. But thats a real good price per axle....I've had to pay 225 for just a d30 from a junk yard. Make an offer tho.
Yes and yes. So does rear wiper. But the window goes with the hatch.. Not seperating them.
They all work, but I'd really like to sell a complete PW/PL kit with door panels and switches...
I believe that I have at least two master switches laying around. I'll look.
I need a passenger side mirror... I'd be willing to take both of your hands if you want to sell as a set. Just let me know a price with flat rate shipping or if you need to calculate it the zip is 47955.
I'm interested in the exhaust, front bumper, and hitch, too. But since it's a pain to ship I'd say go ahead and try to sell them locally first and if you still have them by Winterfest and there's an easy way to get them there then we can go from there.
Edit: Also what color is the interior? If gray then I'd absolutely be interested in the sun visors.
Where in Wis.? I will be out that way for super bowl weekend. I really need the fuel tank as mine is leaking.
Burlington. South east south of milwaukee
The tank is 97 up,only. No 96 or older
so your saying if I can't put a a 96 pump in it? Or is it a tank fitment issue?
97 up are plastic, top load pumps too.
Things that are sold
Trans
engine harness/ecu/tcu
trans cooling lines and external cooler
radiator
rear bumper
front hitch
front axle
headliner
tail lights
complete a/c system
keyless entry
tcase shifter/linkage
front driveshaft
What I have left;
rear hatch - $150
front doors - $150 each
rear doors -$75 each
tinted rear side glass with seals - $50
windshield - $50
dash - $75 complete plastics, no electronics
interior harness - make offer
front clip (fenders, hood, hinges, header panel, front bumper, and inner fenders) - $275 for all of it, or $75 per fender, $100 for header, $50 for bumper
fog light/headlight harness, switch, and lights - $150
door seals - $25 for front, you can have the rears if you want them
engine - $75 needs oil pump but has decent compression.
transfercase - $250
chrysler 8.25 with good brakes - $100
rear driveshaft - $25
e-brake assembly - $25
center console $75 but the mount is broken, console is in nice shape
good seats - $50 for all of them
cruise control - $100
gas tank - $50
rear hitch is trash.
All prices are "Or Best Offer"
I will not ship doors, windshield, rear hatch, gas tank, or axle. obviously they are too big to ship reasonably and you'd be better off getting them locally. I could ship the dash, but it won't be cheap.
Front fenders, hood, bumper, header panel are no longer available. I will need them to fix my jeep...got in a light fender bender today, not bad, but if I have to paint one part I will do the whole front end
:repair: Sorry to hear that Pat! Well at least you still have the parts to fix it! :)
lol. I decided against fixing it at the moment....it's a light ding in the fender. I'll fix that. The header has a vertical crack in it on the driver's side, and the upper rad support got tweeked. If I pull the fender, straighten it, and replace the upper rad support, it will look pretty good still. the bumper after looking at it took no damage. It was a 2 mile/hour collision into an open door...in a parking lot, the guy parked in a spot people don't normally park in and i was heading into the sun. White truck, sun glare, couldn't see it. his door took the damage, but because it swung close, I had little damage on mine.
because I have a ding in the hood and other fender, from the PO, I was going to replace it all...but this jeep isn't perfect and doesn't have to be.
