VegasAnthony
- Las Vegas
I ve heard Napa has speedy outer axle seals for a XJ(TJ) D44 axles
anyone got a part # for these??
Its not a seal,its a new seal surface for the axleshaft itself!JLane99XJ said:"speedy" outer seals??
is that any different than a standard outer seal??
RCP Phx said:Its not a seal,its a new seal surface for the axleshaft itself!
YESVegasAnthony said:but do you still have to press off & on the bearing to put the new seal on??
cLAYH said:When the seal wears a groove into the axle shaft it starts to leak. Putting in a new seal doesn't help as the shaft is worn.
So you buy a speedy sleeve kit which comes with a special seal and a sleeve that slides over the worn portion of the axle giving a new sealing surface. Viola! No more leak!
