Hi everyone. I have a 1999 x's that is giving me the "large leak EVAP" code. I replaced the LDP, gas cap, and found and replaced a cracked steel line. I have smoke tested it and found that my valve cover gasket and oil filler cap had leaks. I was able to tighten the valve cover to correct that and replaced the oil filler cap. I now get no smoke from anywhere in the system when smoke testing. My CEL seams to be staying on. How long until I can no for sure I am fixed? I don't really want to disconnect the battery and wait and see if the light comes back, rather see it shut off when the problem is fixed.
