XJ_Rudolph NAXJA Forum User Location Pleasanton, CA Jul 18, 2015 #41 and put a c clamp around the jaws of the puller to keep them together
J JeepFreak1234 NAXJA Forum User Location San Jose, CA Jul 18, 2015 #42 Can I return it like this? The Pitman atm is still stuck btw
J JeepFreak1234 NAXJA Forum User Location San Jose, CA Jul 18, 2015 #43 It's this what ur talking about
XJ_Rudolph NAXJA Forum User Location Pleasanton, CA Jul 18, 2015 #44 yea they have a lifetime warrantee, iv broken breaker bars and gotten a new ones
J JeepFreak1234 NAXJA Forum User Location San Jose, CA Jul 18, 2015 #47 I have to go to work in a half hour so I'm gonna get a new puller, and I'll come back around 5:30 ish
GordoSmasho Nevada Raisins NAXJA Member Location Virginia City, NV Jul 18, 2015 #48 Once its loaded up a bit. Whack the arm with a hammer. It will help break the tension. If that doesnt work a map torch should do the trick
XJ_Rudolph NAXJA Forum User Location Pleasanton, CA Jul 18, 2015 #49 GordoSmasho said: Once its loaded up a bit. Whack the arm with a hammer. It will help break the tension. Click to expand... Very good idea right there
GordoSmasho Nevada Raisins NAXJA Member Location Virginia City, NV Jul 18, 2015 #51 Any time your using a puller that is good a good practice.
XJ_Rudolph NAXJA Forum User Location Pleasanton, CA Jul 18, 2015 #52 Map torch is just a torch that uses a gas that burns hotter than propane i think.
J JeepFreak1234 NAXJA Forum User Location San Jose, CA Jul 19, 2015 #53 Ok then I was using a map torch and a bfh. What do you mean by "loaded up"?
XJ_Rudolph NAXJA Forum User Location Pleasanton, CA Jul 19, 2015 #54 While there is pressure on the pitman arm, whack the pitman arm with the hammer
J JeepFreak1234 NAXJA Forum User Location San Jose, CA Jul 19, 2015 #55 I did. Nothing happened. Even when I hit it with the torch
XJ_Rudolph NAXJA Forum User Location Pleasanton, CA Jul 19, 2015 #56 Your guna need that impact on there
J JeepFreak1234 NAXJA Forum User Location San Jose, CA Jul 19, 2015 #58 Only 1 hour left of work. Then ima get that piece of shi@ out
J JeepFreak1234 NAXJA Forum User Location San Jose, CA Jul 19, 2015 #59 I'd out just me or it's every reply a new thread. That's what it looks like in my feed at least
