Operation Overcompensation
Something different. Don't want all of the 'Toyotas' looking the same.
cracker said:
The same way I usually get it to JV.................flat tow.
Looking forward to some more wrenching? Don't forget to check your balls.
Gosh...Even I have a trailer now?
JohnX said:
I will double check the ball tomorrow night.
Thanks
GSequoia said:
Whatever.
One nut.
:kissyou:
Mei keeps the other one in her purse :laugh2:
well i was in the neighborhood and i just so happened to see.........
masa' i sees ya on the trail
Totally successful!
A completely new vehicle. 1000# lighter than I used to be 2 months ago and what an incredible difference it makes.
FileHandler.ashx
FileHandler.ashx
I even made Backdoor dor the first time...........
FileHandler.ashx
FileHandler.ashx
Overall, fawking awesome!!!
An EXTRA special thanks goes out to Ron, Robert and Scrappy!
well it worked better on hwy 20 at a certain part then a certain rig with 40s........
I am sure there are some Toy guys that will be forever grateful for that. :D
Ps - - Hey kid, where are the pictures of the finish of the first climb on BD? That image will forever be stuck in my head. :moon:
Ps - - Where are the pictures of the finish of the first climb? That image will forever be stuck in my head. :moon:
This one?
If you can find a picture of it 2' later, can you photoshop my brother back into his original filming spot.......wrapped around your bumper. I woulda lost it seeing him scramble out of the way up onto your hood.
Tomorrow the axle housing (thanks to Troy) gets cut. I have adjusted the dimensions just a hair to move the diff to the drivers side 1/4".
FileHandler.ashx
Ignore these. These are 'notes' from my 44 build I will be using on my 60/9"
Inner C gusset made out of 1/2"
FileHandler.ashx
LCA bracket pre mitered
FileHandler.ashx
Cover plate for the LCA brackets to be fabbed and machined to allow LCA to extend higher.
FileHandler.ashx
FileHandler.ashx
Coil cup to be placed perfectly on center OR behind center if shock mount allows.
FileHandler.ashx
A Work in Progress..............
FileHandler.ashx
Thanks Troy!!!
Wow, looking good. How did Troy get the inner c's on? Did he take it to work and use a press ? I was going to use a really big hammer and pound them on but, I heard bad things can happen that way.
FileHandler.ashx
Thanks Troy!!!
