ok, what is the best long arm kit out there?
JEEPTUBE
citrus heights
crossmember nut broke off weld and is now rolling around in the uni frame. Is there any access panels in the floor to acheive welding the nut back on inside the frame? Or do i have to make an access with mr. plasma cutter?
this belongs and will be moved to the modified tech.
from experiacne rustys arms suck. if I were you i'd be looking at TNTcustoms.com for the Y-Link system/belly xmember skid. clayton and rockkrawler make good products as well
