jimmy21669
- Hagerstown, MD
Ok, so here is the scenario:
I start my XJ and it immediately goes to 75 PSI oil pressure. I get on the highway and the needle pegs at 80 PSI. When I get off the hwy and come to a stop, I am now at 38-40 PSI, and never achieve higher than 50 PSI again.
Meanwhile, oil will be spraying out from somewhere on the passenger side of the engine. It get's all over my ignition wires, oil filter, etc. It is enough to be problematic. I cannot tell where it is coming from.
I have done all of the flush and fills. I removed/cleaned the valve cover and breathers and reinstalled with new gasket. I replaced the oil filter adapter o-ring...
SOMEONE HELP ME PLEASE!!
p.s. 91 XJ Sport 2 DR with 4.0 HO, 179,XXX miles.
