oil leak help
1990heepxj
Apple Valley, Ca
ok i got a pretty good oil leak running off the bell housing and a little off the oil pan. i did the rear main seal and pan gasket still leaking. its leaked there since i got the heep about a month and a half ago so i dunno if something could have happened to the motor. please lend me any suggestions as what to check
Big leakers:
OFA--oil filter adapter.
RMS--ream main seal.
VCG--valve cover gasket.
OPG--oil pan gasket.
DMG--distributor mounting gasket.
TCL--transmission cooler lines.
Clean up the mess and keep looking for the source.
Did you use RTV at the corners of the RMS cap?
Did you use a shot or two of silicone on the RMS upper so it would go in without tearing?
