OBDI Fuel Pressure Regulator
BADaXJ
Maine
Does anyone know the difference between the two part numbers of fuel pressure regulators mounted on the fuel rail that are used in the '91-'96 XJs?
I have a '91 Comanche with an engine from a '95 ZJ and I am unsure which regulator to get since I don't know what the difference is. They appear to be the same and from what I have gathered anything with the regulator on the rail is 39psi...
There are two part numbers available aftermarket, but both list the same '91-'96 4.0 engines as the application suggesting they are interchangeable.
There's no difference that I can figure out, but something must be different if there are two different ones available and the Mopar book lists different parts.
According to the 91-93 Mopar parts book:
5300 5801 (1991 / 1992)
5300 5801 (Up To 1-1-92)
5303 0001 (After 1-1-92)
5303 0001 (1993)
