NP231 rebuild/upgrade recommendations
About the different SYE kits ... I spoke with the guy who owns SBC OffRoad Engineering. They handle all of the online sales for PORC, and he said that *all* of the 231 HD SYE kits are pretty much the same. They all use parts from Taiwan, Korea, Japan, China, etc, and they all order those parts from the same suppliers.
The only difference is Advance Adapters. They manufacture their own tail housings (because that's what they do), but the internals of the kit are the same as the others.
Just some more info for anybody who's reading this.
I just got off the phone with a tech support guy at G2 (thanks for the recommendation, ehall). The G2 guy told me their 231 rebuild kit uses Timken Roller Bearings, Torrington needle bearings, and National seals. The kit also includes Gaskets, O-rings, fork pads, etc. -- he didn't know the brands, but if they paid the same attention to quality as the bearings, they should be good.
I know Timken and Torrington are both top-notch. As for National Seals ... I've used their axle & pinion seals in the past with no problems. Anybody have any comments on National?
Part numbers for G2 rebuild kits (NP231):
37-231 -- (for 87-94 w/24mm input bearing, $95.99 at Summit Racing)
37-231FF -- (for 94-06 w/16mm input bearing, $110.99 at Summit.)
Rebuild Kit: (Master or Partial) - http://www.jbconversions.com/products/np231j/rebuild.php
SYE: (Same kit everyone else offers) - http://www.jbconversions.com/products/sye/np231j_std_sye.php
Good thread on upgrading/rebuilding the 231 - http://www.pirate4x4.com/forum/jeep-non-hardcore/1503778-np231-full-upgrade-build.html
When I did all mine, I got a package deal from Tom Wood's. SYE + Driveshaft was ~$500 shipped. SYE kit was from Teraflex, but again it's the same kit everyone else has, and the custom cut & balanced shaft. I've been very happy with all the parts that I received. Also have the Boostwerks shifter (http://www.naxja.org/forum/showthread.php?t=1113419), and it worked flawlessly and easy to adjust. Much less work involved installing than the Novak
Tom Wood's:
http://www.4xshaft.com/XJCherokee.asp
http://www.4xshaft.com/SYE/AdvAdaptersHDkitandTeraFlex231conversions.html
I have the 242, which can be difficult to get lined up sometimes. Need to dial in the shifter using Full-Time and Neutral positions, then verify against the others. Also needed to notch the ends of the shift gate to give more travel so it wouldn't get bumped out of 4-Low on hits, and enough throw to get it into 2WD without hitting, but that was before changing to the BW shifter
After looking into the quality of various options, this is what I decided to go with:
Rebuild kit: G2 Axles
SYE: Advance Adapters
1.25 inch upgrade: http://www.ebay.com/itm/182465565737 (without the used chain).
Chain: Morse/Borg-Warner HiVo 1.25 inch chain HV-022
Shift linkage: Boostwerks
Thanks to everyone for the info. When the snow melts, I'll be able to start the rebuild. I'll try to do a write-up this Spring.
The front output shafts are the same!
Thanks for the info. The reason I asked about the splines was because I'm getting a 1.25 chain upgrade, which includes the front output shaft, and the sprocket on the rear output shaft. I just wanted to make sure the seller wouldn't send me a wrong-fitting part.
Thanks!
