Jeranta
- Lewisburg,Franklin,Nashville-TN
I'm wondering if the output shafts for the front and rear are splined the same? If they are could the double joint from a front drive shaft be used in the rear?
Then the next step would be to find a driveshaft that would work so the slip yoke could be eliminated.
Sorry if this sounds newbie
I'm sure someone has had the same idea.
